Print missing line in elevation view
noconnorG728Y
Message 1 of 11
noconnorG728Y
Hello
When I created the interior elevation view and sheet. All seems fine until I want to print the sheet. I am missing lines on the printing sheet.
So I am here at the last resort. Attached is the PDF of the sheet
Any suggestion as why it is happening?
Replies (10)
Message 2 of 11
@noconnorG728Y
Can you please mark and show us or attached the rvt file to have a check.
As when i printed your pdf, I can see all the line printed. Can you pls show us wat lines are missing during print.
This is your printout.
Message 3 of 11
noconnorG728Y
Ok I am attaching a screen shot of the interior view as shown. All lines are present but when  I printed, some lines goes missing
Message 4 of 11
@noconnorG728Y
Is your Show Crop region Turned on??
Message 5 of 11
noconnorG728Y
Yes, the crop region is turned on
Message 6 of 11
@noconnorG728Y
Do you have any design option turned on in your view template?
or Have did you assign any view template.
If you have design option -> Check whether is design option is set to <Automatic>.
Message 7 of 11
noconnorG728Y
No Template or design option. I only created phasing.
Message 8 of 11
This is my last try give you option is "Did you use Edit Crop option or Did you try to Unhide categories"
"Did you try open an new file and model some simple element and do a quick  sheet and drag in the view try to print and see whether it is happening in the new file also,please?"
After then - Final thing is "We have to check the file and only tell you whether there are some issue in your visibility setting or export PDF option or the file itself"
Problem can be found only when we get the file , open and see it.
I know you cant send your office working file due to work ethics(can see it from you screenshot).
Message 9 of 11
Uncheck Hide Crop Boundaries (in Printer Setup)
Message 10 of 11
@barthbradley
He's got the solution... thumbs up Smiley Happy
Why didnt I think of this... Smiley Embarassed
Message 11 of 11
noconnorG728Y
Yes! It is working now.
Thank You!
