Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Print combined PDF file, but with different sheet sizes
E__C
Message 1 of 8
E__C
We've jumped into Revit recently and apart from a few hiccups are well on our way. one of the biggest niggles we're dealing with at the moment is how to export PDFs. We're using Revit 2017
The project we're currently working on has a number of sheets we'd like to export into a single PDF.
The problem is these sheets have a number of different sizes / orientation, etc (e.g. A1, A2, A3 / portrait, landscape)
So far we've only been able to export a PDF with 1 paper size and 1 orientation, regardless of how the sheet is arranged.
I've tried to search for a solution on here but I can't seem to find anything or maybe I'm just not thinking of the right search terms.
Can anyone offer any pointers as to how we can have the individual sheets of the pdf created using appropriate page sizes and orientations for each file?
thanks
Euan
Replies (7)
Message 2 of 8
loboarch
This is not possible with just Revit. You would have to have multiple print job and combine later.  It is possible some 3rd party software might make this possible, but i am not familiar enough with the options.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 8
I would create a Sheet Set of each paper size and print one Set at a time.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
You may try to set big and long enough paper and then:
https://www.techwalla.com/articles/how-to-get-rid-of-white-border-in-acrobat
One limitation: it may not work if you have 3D view on the sheet
Rafal Gaweda
Message 5 of 8
@E__C  As @loboarch mentioned, third party add-ins can do this.  I suggest taking a look at XRev Transmit.  (Can google search it)  It will print different sizes and has a built in file renamer that will name the files based on sheet parameters.
It's also great if you have to print PDF's, prints, and DWG export....can do all at once. 😉
Message 6 of 8
This is possible using the Revit plugin Archigrafix Docuflow. Each sheet is presented with the correct size and orientation and exported to PDF as in Revit. It also exports the DWG, IFC and the drawing list. Smiley Happy
A free trial is here: https://www.archigrafix.com/downloads
Message 7 of 8
chrisplyler
I would print to individual files, and then combine them with Acrobat. If I were going to make such a monster. Which I wouldn't do. Because...
...combined files with multiple sheet sizes contained therein are VERY ANNOYING for the people on your distribution list who will print them.
Message 8 of 8
sonicer
it's easy to do with plugin  PF Printer PDF from Bimrvt.cz
Select sheets( custom or standard paper sizes), check print to one PDF file and click print to PDF.
One click and all is done automatically.
