- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello there,
I'm having a big problem with PDF printing. Basically, if I print as PDF with my typical Revit legends for repeating information it rasterizes everything in the sheet, but if I delete the legend from the sheet, the plan comes out as vector. Everything in the legend is text, component or detail lines, so it should be able the export as vector. See below both examples. I've always used legends on my sheets for repetitive information and this is the first time this happens. Please help. I'm using Revit 2017.2
