Precast Stairs Graphics Edit
hliS658H
hliS658H
How to adjust the section of the precast-stairs? They are now all thin lines and no hatch pattern. I do not know where to edit the graphics since I do not see the materials; I also tried to edit object styles, no change even after I change the cut mark from 1 to 5.
Accepted solutions (4)
hliS658H
Thanks for the suggestion - it works.  Is there a way to turn on the hatch pattern?
Simon_Weel
For the material of the stairs:
Click the little dotted button at the end of the line 'Run Type' and you're presented the properties of the run, like material.
hliS658H
It works.  Thanks!
It can be edited through Manage>Object Styles too.
hliS658H
Thank you for showing me this. It is good to know the materials are hidden here and can be edited. You can actually assign different materials to run and landing.
