Possible to split the material of a form?
winstonfoxnelson
winstonfoxnelson
Hey, so like if I make an extrusion or a sweep, can I have one part of it have one appearance, and the other, another? Maybe based on some reference plane splitting the two appearances? Thanks guys. - Winston
No. Create one piece for each material.
A.Sobhy
you can, but not to split the element it self, you can split a surface and after that you can give it another material using Paint Tool, This is the only option you can use until now.
i hope it helps
