Positioning panels in corner
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have made a revit nested family of 2 steelpanels in a 90 degrees corner.
What I want is the outside corner always stick together with those 2 panels.
You can choose different thickness of each panel. Param measuremt is part-1 (deel-1) and part-2 (deel-2)
How can I best made this family, so the corners always stcik together?
Next question is: the user has to give 1 dimension (of deel 1) and the other part (deel-2) has to be together max 1060mm. The minimum of part 1 is 250mm. How can I put this in a formula?
Last question: is it possible if you load in a project thickness 80 (panel-1) that automatically panel 2 is also the same thickness?
Thanks in advance!
