Pop-up dialog box location control:
3 REPLIES 3
forestmwilson
549 Views, 3 Replies
I am trying to figure out how to control the location of dialog boxes. For example, manage links > images > reload form pops up in the second monitor's bottom corner every time. I move it to where I would like it to appear regularly, but it always appears back in the same corner. I have tried the alt+spacebar > m and move it to where I want, and that does not work either.
Is there a way/setting to fix/control where windows pop up?
TIA!
Forest
3 REPLIES 3
You could try resetting the Revit UI back to default settings?
How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings
Jay Colcombe
Autodesk Certified Instructor
@jay_colcombe, thank you for your reply and suggestion.  I would not have thought to try that.
It didn't work; however, while I had my Revit monitor set as "1" it was not checked to "make this my main display."
That appears to have done the trick.
Thanks for your suggestion and reply!
Glad you got it sorted and kudos for letting other know too!
Jay Colcombe
