POLYGON PROBLEM IN REVIT-LUMION TRANSFER
beyzaa.yildiz
beyzaa.yildiz
ı have circular spaces in my project, in revit it looks smooth round without edges, but when ı throw it to the lumıon to render, te polygon numbers decrease and look diagonal. Is there a solution?
I put in the appendix as it appears in both revit and lumıon. Not only here, ıt also educes the softness of the slopes.Ekran Görüntüsü (313).pngEkran Görüntüsü (312).png
goulnazarianh
Hello
Have you tried increasing the surface smoothing during the export to have a nice round corners in Lumion?Try to increase the gauge all the way in.Try to increase the gauge all the way in.
beyzaa.yildiz
no, i didn't know how to do it. i will try, thank you.
beyzaa.yildiz
I tried what you said and it was fixed when I export and do it. but is there any way to increase the polygon when using livesync . thanks a lot.
goulnazarianh
If you click on the Settings and again increase the Surface Smoothing it will do the work.
Here's a screenshot for that. Good Luck!Drag the gauge till the end.Drag the gauge till the end.
beyzaa.yildiz
yes I could not see the setting in front of my eyes. There was an easy way, thank you very much for your help.
nicollecm
Community Visitor
Community Visitor
thanku so much really helpfull!
