Message 1 of 17
Point Cloud Import from Recap not Lining Up in Revit
- Mute
- Permalink
- Report
I was curious if anyone else has had this problem or found a solution:
- I generate a point cloud using drone images with Pix4D, ordinated to the local coordinate system using GCPs in an .las format.
- Bring it in to Recap and the coordinate system is exactly the same for all points. Everything checks out.
- Export as .rcs for Revit.
- Import the .rcs version into Revit by shared coordinates and it comes in offset from where it should be. Almost exactly the same offset regardless of project.
Any ideas as to why this is happening?
