Point cloud display in Revit views / pixel size / dot size
t.metcalf
Message 1 of 30
t.metcalf
Hello there,
Hopefully this is a very basic question. In Recap 360 there's an option to display the individual points of a point cloud at different "point display sizes" (from 1 up to 10).
This is very helpful for areas of scans which have less scan density / resolution.
We're hoping there's a similar option for displaying point clouds in Revit views? Currently all we've found under visibility graphics is the ability to change the color mode.
We typically bring in point clouds in RCP format, if that helps at all.
Thanks in advance.
Replies (29)
Message 21 of 30
RSomppi
"These places" are for solutions.
Try the IDEAS forum to request new features.
Message 22 of 30
wayne
Yep you gotta pay several thousand pounds for Revit then several thousand more pa to get it to work with point clouds.  Hence, why I am still using 2017!  As well as point size, having the same intensity rainbow as Recap and a quick button turn the PC on / off would be useful for a start.
Message 23 of 30
j.joos
very sad, that there is still no solution
Message 24 of 30
victor.misula
AutoCAD has this function and Revit doesn't, something extremely basic for interpreting the point cloud, it's a shame it still doesn't have it, to say the least...
Message 25 of 30
DA.GS
Those working with RVT2024 and above can additionally to changing the pointclouds color to "single color" change the Canvas Theme to dark aswell.
This helps the visibility.
Still would like the ability to change the size of the points though 😇
Message 26 of 30
Isaiah_Narvaez
This worked perfect! Thank you!
Message 27 of 30
WGAJohn
I thought I might see if it was possible to use AI coding to solve this and according to ChatGPT it's not possible at the moment.
"Display settings for point clouds (point size/density) are handled by Revit internally and are not exposed via the API."
Message 28 of 30
HVAC-Novice
Check out Qbitec.
You can change quite a lot of the visibility:
And you also can see the panoramic images from the scan locations (the spheres you see).
You can get a free trial. I just started using point clouds a few weeks ago and can't imagine not using Qbitec anymore. I tried the native point cloud with a recap file..ugggh.... that felt like using stone tools after using power tools. The Qbitec method also uses fewer resources than the recap file. If you spend money on scanning... don't skimp on Qbitec.
I use the point cloud all the time even in design after I built the existing model. I work in remodels and it is just great to see all the time what is going on in a space.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 29 of 30
tilo_pfliegner
ChatGPT is right, and so is HVAC-Novice
Message 30 of 30
RSomppi
And others...
