Plumbing Fixtures: Linked model visualization
XXalessio.amodioXX
XXalessio.amodioXX
Hi all,
I have to prepare Tile cutting drawings (Bathrooms, Cleaning rooms ...)
I have a Linked Plumbing model with proper position and dimensions of Plumbing Fixtures.
I want to show the Plumbing Fixtures in BLACK color (In linked model are after Plumbing System colorID)
NB I ahve tried already to assign BLACK color to Plumbing fixture in Revit link VG. Not working. Same for Filters.
Any Idea?
lucdoucet_msdl
@XXalessio.amodioXX
When you talk about plumbing system colours then filters not working, so you mean this technique doesn’t work?
Linked File Revit MEP has Colors
https://revitoped.blogspot.com/2015/04/linked-file-revit-mep-has-colors.html?m=1
As I understand Revit graphic overrides, a revit family override does not supercede a mechanical systems color assignment. You need to override the system color assignment with your filter.
-luc
Edwin.Rense
I would check the linked file to see if the Plumbing fixtures in there do have nested families which are a different category.
What is the result when your linked files are 'selectable' and you select the plumbing fixture with <Tab>
What properties show?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
XXalessio.amodioXX
@lucdoucet_msdl @Edwin.Rense
Here is an explaination video
XXalessio.amodioXX
I did not check properly the link. It worked Thanks
Edwin.Rense
I agree with @lucdoucet_msdl,
This most probably is a filter which depends on the system abbreviation.
Do you have any other views where the piping shows? What color are they?
Is there a view filter active.
Easiest way to check is to open the linked file in an extra Revit session so it does not unload from your current project.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
