Plumb concrete Beams on a sloped slab
pradipto_banerjee
pradipto_banerjee
Hi folks!
I am trying to place concrete beams on a sloped surface. The goal is to have the edges of the rectangular beam be plumb and the bottom of the beam be parallel to the slope of the surface.
If I just host the beams on the bottom of the slab as the work plane, I get the condition shown in the left in the sketch below. I do need the condition on the right. I have at least 2 different slopes, and do not want to bake in an "angle" parameter into the beam family. Is there another way to achieve this?
Many thanks in advance!
Basam.Yousif
I think you need a new custom family here. I'm sure someone made it, if you search. What version of Revit is this?
pradipto_banerjee
Thank you Basam. This project is in Revit 2022.
I'm trying to think of how to make the family - it's workplane based, but also vertical...
Basam.Yousif
All you need is a beam family created like this
