Plotting
3 REPLIES 3
259 Views, 3 Replies
Plotting
We are having accuracy problems with plots. The paper size we are using-dsize is plotting about 10% too small. So the plots re not accurate. We are using an HP 1050. Also raster plots work sometimes but the title and border come out gray scale. We are using the same driver we use for AutoCAD.
Plotting
3 REPLIES 3
Make sure zoom is checked and set to 100% under
Print Setup.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
We
AutoCAD.
Print Setup.
We
AutoCAD.
Does AutoCAD still use the "heidi" drivers?
If so, its not the same as Revit uses standard Windows drivers.
We
AutoCAD.
We
AutoCAD.
Did you ever find a solution to your plotting problem? We are having the same problem is why i'm asking and any help would be greatly appreciated!
