Plotting with the link's filled patterns
Hi all,
I have an arch link in my mechanical project, but then client sent me their architectural model as they did some adjustments, so it changed the printing of the walls.
Before reloading the link the plot looked like that:
And now with the new link in plotted file walls are not filled and look like that:
I have tried the cut pattern to be solid for walls, the object styles in both visibility graphics of the floor plan and of the link itself and there are no changes after that.
Do you have any idea how to fix that?
Thanks.
So there is an update with this issue.
I have changed the discipline in all the views to Coordination and it kinda helped: the main walls that are going from the 1 level to the 3 level are solid filled and the partition interior walls (from slab to slab) are still not hatched.
Creating filters, changing level of detail to fine - tries and it didn't work.
And the interesting part is that in the architectural model itself all the walls are solid filled!
