plotting 3d views from Revit model on HP Design Jet T795
pete
pete
When plotting 3D views of Revit (2019) model much of model does not plot-  there are large blank (white) swaths where the model should be.  Text placed in view does plot.  When printing on smaller printer using (11 x 17" paper)  everything shows up.
nmarcelis
Try publishing a pdf of the sheets you want to plot, and print that pdf from acrobat pdf.
This way you can eliminate if the problem occurs in Revit or of its settings from the plotter.
If this helps please accept this as a solution
Revit Certified Professional Architecture, Structure and MEP.
you can use also pdf creator form forge as a free solution
nmarcelis
What is the purpose of the imported dwg?
pete
Please explain what "publishing" means.  I created a PDF in Adobe Acrobat but I still have the same problem.
