Please help with massing
khuthuie15
khuthuie15
Hey, I’m trying to apply materials on a mass I made on dynamo but i get an error massage saying “mass contains both solid and mesh geometry. Mass floors,volume, and surface area may appear incorrect please help
Yien_Chao
so you made a Dynamo.. maybe the issue is there. can you share more context and the node?
khuthuie15
Yien_Chao
from what i see... i dont think you have a mass in Revit, but in only in Dynamo. the first image is just a preview in wireframe i believe. you will need to use DirectShape node to have a element in Revit. THen... you can add material.
khuthuie15
 hope this is better quality
Yien_Chao
just share the node
khuthuie15
I think the problem might be else where ,I tried this but I’m getting the same warning massage
