Wall wrap function incorrectly
1 ANTWORT 1
Nachricht 1 von 2
BDENGF96VQ
144 Aufrufe, 1 Antwort
I have created a wall with the layers that I want, and a window family with a 'void' to cut out using 'Wall Closure' reference planes. Though the whenever I change the depth of the wall closure to be smaller than the wall thickness, it functions weirdly and thickens the 'exterior' layer instead of wrap it around the opening. See images.
Can anyone help me with this?
1 ANTWORT 1
Nachricht 2 von 2
emmanoelneri
als Antwort auf: BDENGF96VQ
I think thats a problema in your window family.
To make this you want (I understood correctly) try those 2 options:
1 - Besides a window family, make a wall-based family, e set the void with planes correctly. When you cut the wall, control the planes wth a parameter (as you did). The void will cut only the volume needed.
2 - Try to use 3 diffentes wall (Each layer is a unique wall). And then place de window in the intermidiate wall.
Let us know if it worked, or not!
