Please help - Model Lines Not Appearing as the Should
robmarch
robmarch
Good day,
Hoping someone could help me out.
I'm using model lines to do millwork elevations. I have a model line for short hidden/dashed lines for door swing. However, whenever I use any hidden or dashed line type it shows up as a solid line, in 3D and 2D. If I convert to a detail line it shows properly. But I want them to apear in 3D for walk thru's.
When I initially drew them in they showed as dashed, but now I'm not sure what may have happened. Does anyone have any suggestions?
Your help would be so appreciated.
Johan_Ekstrom
Is it a scale-issue? The scale of the view is to large for the lines to show dashed properly?
Type x and y with every move in AutoCad and no one bats an eye...but use coordinates in Revit and everybody loses their mind.
