PLEASE HELP - intersecting roof
emmacain
Message 1 of 9
emmacain
I'm hoping someone can help me & quickly ....
I am trying to draw a second roof with gable ends that intersects with another roof.
I'm really stuck on how to do this & would really appreciate any help/feedback.
Em.
Accepted solutions (4)
Replies (8)
Message 2 of 9
RDAOU
@emmacain
Option A: using one roof by footprint
Edit the main roof >>> Use slope arrows to define the gable
Option B:
Do not extrude it all the way through. Use the tool roof join then cut the main using the opening tools.
Repeat on the opposite plane/side
Message 3 of 9
emmacain
@RDAOU Thank you so much for getting back to me...
Sorry, I don't really understand the first option & I've tried to join with roof tool, but still no luck. I'll attach some pics...I need the highlighted roof circled in yellow to be gone but I can't figure out how to do it??
Message 4 of 9
RDAOU
@emmacain
Here is the first method..no cutouts needed. You can apply it to both planes, all 4 planes or just one.
Message 5 of 9
RDAOU
@emmacain
And here is how to apply a dormer opening to main roof
  • Navigate to Architecture Tab
  • Select Dormer from Openings Contextual Menu
  • Pick Main roof to cut
  • Pick the bottom edges/planes of the Dormer and last the eave of the main roof
  • Use trim to close the loop
  • apply to create the opening
Message 6 of 9
emmacain
Hi RDAOU - wow - that is amazing! Thank you so much for your generous help - I really appreciate it!
All the best,
Em.
Message 7 of 9
emmacain
Hi RDAOU,
Another quick question - does it matter if the roof isn't a rectangular shape? Please see image attached....
Thanks again!
Message 8 of 9
RDAOU
All the best,
Em.
@emmacain
Both methods work for none rectangular shapes.
If you have a sketch of how the final footprint would look like I can capture a GIF showing you how to tackle it..Unless you wish to experiment on your own first then come back for specific questions 🙂
Message 9 of 9
emmacain
Hi RDAOU,
Thank you - I have attached a floorplan above. I will also attach Elevations so you can see : )
