Please help creating a house plan
kegarc2002
Message 1 of 8
kegarc2002
Hi guys:
Can someone please, show me the correct workflow to successfully create a residential building?
Some videos (YouTube) show only AutoCAD. Other import a drawing from ACAD into Revit. Others just Revit.
I'm a beginner in construction. making the transition from mechanical to architectural drawings. Dead in the water.
Anything helps. Tutorials, Courses...anything
Please help.
Thanks in advance
Replies (7)
Message 2 of 8
Alfredo_Medina
Have you searched on Youtube? There are plenty of videos with this topic, even complete courses organized by lessons. All free. It does not seem difficult to find.
Message 3 of 8
kegarc2002
Thanks Medina for the fast response.
In your opinion:
Which of these three’s options I mentioned in my post, is the right one?
Thanks in advance
Message 4 of 8
mhiserZFHXS
There is no singular correct answer for this. You can use CAD as a starting point if you want, but you don't have to.
As noted, you should really try to find a structured introduction to the program.
Message 5 of 8
SteveKStafford
A lot of people start learning by drawing modeling their own home. Look for a book called Residential Design Using Revit 2024 by Daniel Stine. It will walk you through the process. There are lots of books you can study from as well as videos online. If you have access to Linked In Learning there are courses there too.
Steve Stafford
Message 6 of 8
Alfredo_Medina
In your opinion:
Thanks in advance
Follow the tutorials that do not use AutoCAD drawings as a starting point to make a Revit model.
Message 7 of 8
kegarc2002
Thank you, Steve for your help.
Just what I needed. Found and bought from Amazon.
Table of Contents
1. Getting Started with Autodesk Revit 2024
2. Lake Cabin: Floor Plan
3. Overview of Linework and Modify Tools
4. Drawing 2D Architectural Objects
5. Floor Plan (First Floor)
6. Floor Plans (Second Floor and Basement Plans)
7. Annotation
8. Roof
9. Floor Systems and Reflected Ceiling Plans
10. Elevations
11. Sections
12. Interior Design
13. Schedules
14. Site Tools & Photo-Realistic Rendering
15. Construction Documents Set
Thanks for the help.
Message 8 of 8
myeager171
Simple, it depends on what you have to start with. Nothing then you don't need anything but Revit. If you have an AutoCAD file use it it will save some time.
