Planting visibility in sheets
aldo_verbergt
aldo_verbergt
Hi all,
This might possibly be something easy that I overlooked, but I'm not successful at location the problem.
I'm working on a presentation for the facades of a project and on almost all sheets the planting is visible just as we need it (Planting 1 screenshot), but on one of the sheets suddenly all planting is transparant (Planting 2).
I've checked the V/GO, made a view template based on one of the correct views, nothing seems to work.
Any ideas what it might be? Thanks in advance.
ralphdenhaan
Can you share the Planting family? Maybe it has something to do with the Element Visibility Settings in different displays and different lines/masking region.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
syman2000
Did you try right clicking on the object and check if the planting transparency override by element.
aldo_verbergt
@ralphdenhaan  that was it, so stupid, thanks!
