Plantation not showing on floor
Hello
Why does only half of my plants showing?
When i move them towards the left, they appear again.
How do i make the plants appear on the right hand side?
ennujozlagam
cut a section and move them upward or offset them from the level upward?
ennujozlagam
another way is select your plant > go to properties and select foreground instead of background? thanks
RDAOU
@Anonymous
And what happens if you move them Right???
Try to nudge the trees to the right or Hover cursor over a tree...If it highlights/shows highlighted, then you need to check if they are being masked by a region, a generic annotation or another family/component that has a region nested into it
