Message 1 of 8
08:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a building with a lot of different levels. One room is 1m higher than the other, etc.
I was first working with offsets but it was becoming too hard, because I have too many different things, so I created different levels. For example, "ground floor upper" "Ground floor lower".
However, I want to be able to export it and see both levels at the same time. And no matter how I change the view range, I still don't see the region masks of the other levels, or the room tags.
What is the smarter way I can be working with different levels but being able to export a plan that shows everything from both levels?
