Plan view
Plan view
Plan view
I created a plane view for my footing with all its anchor plates only. I disabled all views except for structural footing and structural connection.
Why am I getting views from anchor plates( which are also structural connection) from my walls?
But I don't have walls selected?
Is there anyway I can tell that these anchor plates are part of the walls?
If I understand you correctly,  you do not want the Walls' anchor plates visible in the view. Is this correct? You could filter them out of the view based on an identifier they have that is different from the footing anchor plates.  For instance, you could filter them by "Mark" or "Comment" value .
Just wondering if you can do a screencast for me
   Thanks kindly
ennujozlagam
@Anonymous hello, you can create a view template, untick those visibilty you don't need and apply to your new created views or you can refer to this LINK. thanks
