Strange wall to be build in Revit
2 ANTWORTEN 2
Nachricht 1 von 3
423 Aufrufe, 2 Antworten
Hey guys, any suggestions how to build a wall like this in Revit? It is made from a single element that is just multiplied in different directions? It is used for walls and windows. First I did a simple family and then copied it around, but it takes a bit too much time, so I was wondering if you could suggest something? First I would like to use it to create plans and sections, but then I would like to render it, so that is the reason why I would lie to have the exact elements in place :)) Thank you!
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Try to build one unit as a sweep blend generic model, nest it in a curtain panel family, and use it is a curtain wall or curtain system in project.
You can also try a pattern base curtain panel or adaptive generic family and host and repeat on a divided surface.
Nachricht 3 von 3
als Antwort auf: ToanDN
@Anonymous: I'd talk the client into EIFS! Seriously though: very unique. I like it a lot!
