Plan regions
Plan regions
Plan regions
Is there a way to turn off a plan region not just hide the lines.... i.e.  where it would be completely invisible in certain views? In other words, you could show a clerestory of windows on a floor plan.... but not see the windows in the roof plan...
Is there a way to completely turn off a plan region? i.e. see clerestory windows in a floor plan.... Not see it at all in a roof plan?
cbcarch
Perhaps you can use an Underlay of an upper / clerestory Level in the Floor Plan to see the Clerestory--to achieve this?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
I am not quite understanding. Plan regions only modify the view range. They are view dependent so a plan region in a floor plan view should not be in a roof plan view.
RobDraw
Just delete it!
Rob
Corsten.Au
Hi
Plan regions are view specific..so if you don't need certain plan region then just delete it..
Even after that if windows are showing up on Roof Plan, then you need to fix
the underlay, View range.
this should fix it, else you will have to look into Windows family for the graphics..
Cheers!
Corsten
Building Designer
