Plan Region not cutting wall as expected
How come Plan Region won`t cut where I tell it to? It shows the walls, but not the layers as you can see in the picture. I have added the properties for the walls to for better understanding. View Range in Floor Plan is set to Top: 2300, Cut Plane: 1500. In Plan Region I have tried several values, in picture it is set to; Top: 800, Cut Plane: 300.
What are the View Range settings of both the View and the Plan Region?
Example:
Except for the settings I already mentioned?
See attachment
How tall is the wall? I bet it is shorter than 1.8m.
Oh I just looked at your screenshot and the wall is short.  Make the top constrained to the same level and top offset = 1350 mm, base offset = -303 mm.  Then the plan region will show the layers.
Set your Bottom and Depth to Unlimited.
Unlimited worked, but thank you to both. I think i understand this better. Or maybe not XD
