Plan not available in underlay drop down list anymore
SCOTTALLEN3416
Observer Observer
SCOTTALLEN3416
Observer
Observer
I upgraded to 2025 and now i have a plan than isn't associated with a level that used to be an option to use as an underlay.
It is no longer available as an underlay option.
It is an equipment plan, that i would like to see the equipment placement on other levels as an underlay.
Is there a way to make this plan available in underlay drop down list?
RDAOU
@SCOTTALLEN3416
What is listed in the underly drop down menu are the levels and not views.
A level could have multiple floor plan views, detail view, horizontal section views ...etc; these do not get listed in the underlay drop down menu, never were before. Hence, regardless if the view exists or doesnt exist associated or not associated, they are not what you see in the drop down menu.
I am curious though, was the floor plan in the previous version associated with a level and after upgrade to 2025 it is no longer associated?
handjonathan
Hi @SCOTTALLEN3416
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Underlay shows Levels, not views.  And only Levels with associated views can be used for Underlay.
