placing decal causes object to go transparent and not display decal correctly
dariusduke01
dariusduke01
Hi, all when I place a decal my object gets completely screwed up and the material becomes transparent not displaying the decal correctly. In 2020 I had no issue placing decals on my work. And using decals are a huge part of it.
Please help it driving me crazy, the only thing I can think of is reinstalling Revit as it looks like a program issue.
syman2000
Sounds like 2021 issue. This user also have the same user as your. It works fine with 2020 or lower.
https://forums.autodesk.com/t5/revit-architecture-forum/decal-did-not-show-in-rendering/m-p/9508488
GOT LUMINANCE?
Render the View.  Does it show up? If so, then it's behaving as designed/documented.
"The detailed decal image is visible only in rendered images."
Place a Decal in a View | Revit Products 2021 | Autodesk Knowledge Network
