Placing Ceiling fan
Placing Ceiling fan
glkirk
Message 1 of 10
Placing Ceiling fan
glkirk
Why do I always have such a hard time placing ceiling fans.
I cant get it do do anything but briefly show in an elevation off the building, but just goes away when I try to move it.
I cant see any way to place on a work plane?!
Appreciate any help.
Replies (9)
Message 2 of 10
hmunsell
it may have to do with how the family was created.  can you upload the family for us to look at?
Do you get these options when you place the family. if you do, try picking the Place on Face or Place on Work Plane option.
Howard Munsell
Message 3 of 10
glkirk
No, I don't see any of those things.
In the past, sometimes, I had seen them and maybe, had been able to manipulate.
Today I have DL 5 different fans from Revit city, and have finally found one that I can deal with.
How do I DL a fan file?
Message 4 of 10
hmunsell
the fan you initially tried using was likely a hosted family then.  Are you asking how to DL a family from Revit City or how to Upload a family to the post :-).
to upload the family to the post, scroll down to where it says Attachments and drag the family into the box.
Howard Munsell
Message 5 of 10
RobDraw
There are some poorly designed families at that site. I've never had any luck there. Why aren't you using manufacturer's families?
Rob
Message 6 of 10
syman2000
Have you look at manufacturer fan like bigassfan?
https://www.bigassfans.com/ca/aedownloads/
Message 7 of 10
RobDraw
You're welcome.
Rob
Message 8 of 10
@glkirk: I see that you are discovering the limitations of hosted families – in particular the Ceiling-Hosted Family. For what it’s worth, there exists a neat little trick you can use to convert a hosted family to a face-based or non-hosted family. Keep it in your repertoire. It’ll come in handy.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/conve...
Message 9 of 10
The most prominent vibe and an easy task to be taken is this without anyone's help!
The prominence of roof fans keeps on developing as an ever-increasing number of mortgage holders find emotional, all year energy investment funds. In summer, roof fans make cooling breezes, which decrease the strain on climate control systems. In winter, they flow warmed air to keep the room warm.
Introducing a roof fan is moderately basic, particularly if the space above is open from a storage room. Be that as it may, in any event, when it isn't, the employment is still very possible. Here, we'll tell the best way to supplant an old light installation with another roof fan and light, in a life with no storage room above. The upside of this methodology is that you don't need to run new wiring. The fan interfaces with the current link from the old light.
Nonetheless—and this is significant—you can't simply drape the fan from the current electrical box. It's basically not sufficiently able to help the additional weight and vibration of a fan. Assuming you don't approach the roof fan from above, you should either utilize an exceptionally evaluated holder and box to mount the fan between joists or, even better, screw a fan-appraised "hotcake" box (supposed in light of the fact that it's extremely meager) straightforwardly to a roof joist.
Message 10 of 10
RobDraw
Roof fan?
Rob
