Placing a Sweep inside window family.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am learning families and decided to make my window frame a bit nicer with a Sweep, but I also wanted to parametrise how deep in the wall the window sits. I made my Sweep and tried to add a dimension with a parameter assigned, but the constraint was breaking. I Alligned the sweep to the Reference Plane and assigned a parameter to the sweep offset, that was basicly moving my Reference planes around.
Then I placed them without constraint with a parameter to the offset, and it worked in the family editor, but on the wall, there was some extra offset.
I finally noticed that Sweeps have a WORK PLANE, which earlier I didn't touch cos they were greyed out. Now it finally seems to work, but I still should ask some question.
I stayed for now with the parameter assigned to the Sweep Profile Offset, but I noticed that the native Revit window families prefer adding a bunch of extra reference planes and adding parameters to them (via dimensions). Is it only a convention, or is there a solid reason why I should do it this way?
I mean, it took me many tries before I finally understood how to incorporate Sweef into a window family, so I am not quite sure this iteration is error-resistant.
