Place Wall with grid in structure
Hi all. I have a wall with 350mm reinforce concrete and internal insulation.
When I am placing this wall into a grid, it takes the center of the thikness..
What I want to do is to place this wall centered with the 350mm reinforce concrete. How can we achieve this
If your concrete is set to be Core in the wall properties and the insulation is outside of the core, you can change your wall justification in the options bar to "Core Centerline"
