Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
From Point Clouds to Revit
I am a Surveying and Geomatics engineering final year student. I am working on my end of studies project about creating an as built BIM from point clouds data.
My question is how to process that? does anyone of you have a webinar or a video that illustrates an example of modelling a building (indoor scenes included)  ?
Manal
kennyj
Most as-builts that utilize point scan clouds are already modeled; the scan is to verify construction variances.  So a BIM would have been created to get the permits and construciton documents, then a scan would be overlaid to confirm the final results and make adjustments for construction changes.
Scan Cloud registration software (Recap & Cyclone) can generate planes/surfaces and basic shapes from the scan cloud to allow modeling from the point cloud, but this generally results in a very large file size and is often not very accurate (the walls will not be plumb, for example).  This works fine for simulations and gaming, though.
Good luck!
kennyj
The building I am working on is a historical building that requires refurbishment So there is no BIM model already done. As for softwares, I am intending to work with Edgewise and Pointsense Plugins in Revit. They are pretty strong tools at extracting objects and surfaces.
