- Mute
- Permalink
- Report
Hello all,
Is there any workaround in order to place a norma doot to a curtain wall?
Thank you in advance!
Hello all,
First, load a normal wall as a panel in the curtain wall. Then you can place a normal door in that wall.
To explain a bit further:
-You may need to make a thin (1" thick to match glass for instance) Wall Type.
-Then, use Tab key to highlight the curtain panel, unpin it, and select the thin wall as the panel type.
-Then, as Alf says, place a normal wall hosted door into the "wall" panel.
