Problem:
The problem is that a sheet of detail views printed to Bluebeam PDF prints correctly EXCEPT for a single individual detail on the sheet that prints out with jagged "pixelated" lines, all others print correctly. Print settings are set to Vector of course, and I have tried switching on and off the anti-aliasing setting but neither setting resolved the issue. See attached PDF.
Solution:
Upon further investigation it was revealed that the detail view in question was called out as a Detail View type. Changing it to a Section view type enabled the Depth Cue setting, and the Depth Cue feature was in fact enabled (despite previously showing as NOT selected). Has anyone else experienced problems with jagged lines printed from PDF with the Depth Cue setting switched on?
