Pipe running horizontally not vertically
Hello. I want to place a pipe running horizontally not vertically.
Cannot find how to do it. Help appreciated.
Actually I cannot see any pipes, I check VG and visibility setting in the template, havent found why..
chrisplyler
You're placing them at an elevation that is outside of your view's View Range?
RDAOU
@Anonymous
I think this is a duplicate post to the following one!!
https://forums.autodesk.com/t5/revit-architecture/no-auto-route-solution-found/m-p/6368136/highlight/false#M118926
- You need to define the fittings for the pipe type... Select >> Edit Type >> and load the fittings then assign them...
See reply to your other post & Screencast
