Picket tile hatch pattern
laurelcholland
laurelcholland
Community Visitor
Community Visitor
Does anyone have a picket tile shape Revit download to use on a shower elevation? A model Hatch pattern?
syman2000
Is this what you are looking for?
hello3YMWK
Community Visitor
Community Visitor
YES! Thank you so much, @syman2000! That's what I was looking for! Did you write your own .pat file? Is there a way to customize them and resize in revit to be 3x12 tiles?
Thank you for your help! I appreciate it!
syman2000
You can create the pattern using Pyrevit plugin. First draw the pattern using drafting lines and then export them to create the pattern.
hello3YMWK
Community Visitor
Community Visitor
@syman2000 Is that program compatible with Revit LT? Thank you!
syman2000
Sadly LT won't allow plugin. The other way to create your own is using AutoCAD and use this plugin
https://cadtips.cadalyst.com/patterns/hatch-maker
If you don't have AutoCAD, you can check out this website to create hatch online
https://pattycake.io/
As well, I've create the tile 3x12
