Pick Line ( 3d Space )
Hello .
I am trying To Draw Reference Line By Pick Line Tool .
I want to draw the line exactly in the same place in 3d View .
The Problem Is that the line drawn  As projection at the (Work Plane) .
It's too hard to specify the work plane manually becuse the line are curve in the model  .
so I will Appreciate if you could help me How to pick line in the same place and same 3d rotation . !
Thank you .
Abdulrahman
Ilic.Andrej
If you re writing about a Reference Line, there s gotta be something that hosts it. You can draw reference plane and then use that plane to host the line (geometry faces can do it as well). First, set the work plane, and then you can use "pick lines". There is no other way.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Corsten.Au
hi
1. select the model line...
2. go to section or elevation
3. select previous ( so that you select that model line )
4. now copy vertically up by dragging, if it doesn't  allow then uncheck Constraint, and unckeck Disjoin and now
    you should be above to copy it vertically up.....
Corsten
Building Designer
