Phasing / visibility issue
Daisyl92
Message 1 of 29
Daisyl92
Can someone explain what I have done, for some reason one 'new construction' window is not showing aside from the swing but as you can see the long window under the same phase is. I have played with phases and visibility in regards to coarse to fine details and can only get the window to show when the Demo lines don't but I need them both.
Thank you !
Screen Shot 2020-08-12 at 3.47.32 pm.pngScreen Shot 2020-08-12 at 3.56.21 pm.pngScreen Shot 2020-08-12 at 4.00.52 pm.pngScreen Shot 2020-08-12 at 3.56.31 pm.png
Replies (28)
Message 2 of 29
_Vijay
Hope below links  will help you...
https://bimscape.com/autodesk-revit-introduction-phases/
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
http://www.revitzone.com/revit-fundamentals/62-phases-an-overview-of-revit-phases
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 29
Set View Phase Filter=Show Complete, Phase=New Construction. Report back.
Actually, I think you want Phase Filter=Show Demo + New.  Right?
One more FWIW:
Message 4 of 29
bin
What is the create and demolish phase of that window?
Message 5 of 29
martijn_pater
Is the window curtain wall based? Could be there might be some phasing issue, try copy-pasting the window in same place with the view set to its construction phase...
Message 6 of 29
infoWL2PN
It looks like you're implying that both windows are supposed to be of New Construction. If so, did you check whether the window on the right is in an Existing phase status?
Message 7 of 29
Your phase filters are strange to start with. Did you change them from the original settings intentionally or by mistakes?
Message 8 of 29
Daisyl92
Both windows of this elevation are under ' new construction' it appears to be only an issue on this elevation
Message 9 of 29
you still having issues?  Post your file.
...are you sure the elevation marker cut plane is set back from the wall far enough?
Message 10 of 29
Daisyl92
I use 'show complete' and 'show new and existing' to show with and without demo lines. I have used these settings with another model which worked but happy to change if it'll help!
Message 11 of 29
I don't think it has anything to do with Phase Filters if it is happening in only one view. Maybe I'm wrong.
Message 12 of 29
Daisyl92
Maybe coloured helps? the red dash is demo is set as overridden. The "new construction" windows seem to be blanked out aside from where one overlaps with an "existing" demo'd window
Screen Shot 2020-08-13 at 8.24.53 am.pngScreen Shot 2020-08-13 at 8.34.01 am.pngScreen Shot 2020-08-13 at 8.33.25 am.pngScreen Shot 2020-08-13 at 8.33.42 am.png
Message 13 of 29
Can't you just post the file? Make it a heck of a lot easier. We could put this to bed in a matter of minutes.
Message 14 of 29
bin
Move your new window horizontally a bit and see if it will come out, it can be hidden because it's not cutting the infilled wall.
Message 15 of 29
Daisyl92
Thank you for your time!
Message 16 of 29
bin
The problem you are having is:  The part of demolished wall created when you place a new window is blocking your new window.
You can use unjoin tool an click on the infill wall(demolished)/window to separate the infill wall(demolished) from the existing wall, then override graphic the infill wall to make it 100% transparent.
bin_1-1597273896492.pngT
You will be able to show the new windows with the demolish lines of the infill wall.
If you don't want to see the demolish line, simply skip the uncut and Tab select the infill wall to hide it.
Message 17 of 29
Isn't this what you want to see with Show Complete?
Message 18 of 29
Daisyl92
That plus the demo lines of the old window. It is for a DA and I need to show the new openings (shown) but also the window/s we are removing (in red dashed).
Message 19 of 29
Daisyl92
It is, but the window detail is incorrect. I am hoping to have the same detail of windows regardless of what wall (existing or new wall)
It seems if an existing window sits on existing wall it shows correctly as well as new window on new wall but when a new window is set in existing wall the detail.
The window shows correctly if I remove the demo phase in the settings but I need to show the demo as well.
Message 20 of 29
Hide the Infill Wall then.
