Phases - Halftone display of existing elements
johnharvey
Message 1 of 13
johnharvey
I having problems with random elements not displaying in halftone as set in the phasing overrides.
I have seen other posts with similar issues but haven't found a solution.
Has anyone solved this problem?
Replies (12)
Message 2 of 13
kadmonkee
check the elements not changing "Phase Created in " setting
are these in your live model or a linked model?
are you using filters or view templates?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 13
johnharvey
Hey kadmonkee.
Thank you for your reply to my post
The elements that are not displaying in halftone are created in the "Existing Phase".
The elements are in the live model and not in the linked model.
I am using filters and view templates but the filters are not applied to the elements in question and there are also no overrides applied to these elements.
Message 4 of 13
kadmonkee
have you confirmed if any Object Style overrides have been applied?
sometimes the subcategory within a family is driving the result
thank you
Message 5 of 13
Can you give a little bit more information on what they are?   Perhaps a screen grab of the view showing some of them, the view's Phase/Phase filter properties, and Phase Filter / Phasing Graphic Override windows?
Message 6 of 13
Viveka_CD
Hi @johnharvey
  • Select the elements for the existing phase (do you want these elements to remain in the background?)
  • Right click and select "Override Graphics in View" > By element
  • Define a value "1" for "Surface Transparency"
It would help to analyse the issue better if you provide a screenshot of the settings.
Message 7 of 13
johnharvey
Hi Kadmonkee.
There are no graphic overrides applied.
John.
Message 8 of 13
johnharvey
Hi ToanDN.
See attached screen shots.
No graphic overrides applied.
John
Message 9 of 13
chrisplyler
What is the Bottom of the View Range of that view? I notice that the walls in question seem to be below the Level, and I wonder if they might be getting overridden by the <Beyond> line style.
Message 10 of 13
@chrisplyler is spot on.  Make your View Range bottom to match View Depth and it will fix.
Message 11 of 13
chrisplyler
Woooohooooo I'm spot on!
Message 12 of 13
johnharvey
Thanks everyone for your help so far.
I'll try the view range tomorrow morning.
Regards
John
Message 13 of 13
johnharvey
Thanks Chrisplyler and ToanDN for your assistance.
Your suggestion has worked.
Great stuff.
Regards
John Harvey
