Phantom wall impacting room areas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are working on a remodel project where the Revit model was started a few years ago, by staff that is no longer here, so not available to question what may have happened here.
Now that we are beginning to work on it again, there appears to be a phantom wall intersecting rooms on one floor. No existing, demo or new walls are located here on this level or above/below. There are also no hidden room separation lines. This 'phantom wall' appears to be 8" and impacts the rooms in both the existing and new construction phases, in plan, section and 3D views.
We have tried all the various ways around tracking this wall/room separation down, and have yet to find it. Room Separation lines are visible, and none are anywhere near this part of the building. Filtering out all walls, at all levels does not find anything here either. Similarly, going thru all the wall types in the project and choosing to 'Select all Instances' does not find anything at this location. Same with doors, just in case there is a 20' long door opening or something. No model items are hidden at this location. Other walls and room separation lines can intersect/interact with this, but you can not select to extend to it or snap to its end.
Have purged and audited the project with no changes.
Snapshots below show with the room(s) surrounding this area selected for ease of viewing them being intersected; shown in the 'new construction' plan and section thru the corridor (but the existing and demo act the same). Going back to early PDF prints of the project the original staff worked on, shows as masking out the rooms there as well, so assume whatever originally caused this was un-intentional and ignored at the time.
Any suggestions on what else to look for?
(we are currently working on this in R-19, but have also upgraded a copy to R-21 without change).
Plan view - new construction
section view
