Perspective mode simply doesn't work - help appreciated (look at the video)
jsanders
Message 1 of 51
jsanders
When I click on perspective mode, all hell breaks lose and the angle is extremely wide. Furthermore, the middle mouse button stops working and I can't orbit around my model. To orbit I have to manually grab the navigation bar and click on "orbit" button. I'm sure that this is not how Autodesk intended perspective mode to be used.
Why can't Autodesk implement a simple persepctive mode like Navisworks or even other software like Sketchup ?
Thanks for your help.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Replies (50)
Message 41 of 51
That Architectural template is an RTE file. If you click on browse button in that window it will show you a list of RTe files.
Message 42 of 51
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jsanders
It seems default french template DefaultFRAFRA.rte has corrupted 3D View.
Please use attached one.
Rafal Gaweda
Message 43 of 51
jsanders
Message for @ToanDN
Here is the .rte file https://we.tl/t-4XsbK0iPrd
(tried to upload via the forum upload but doesn't work for some reason).
Message 44 of 51
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jsanders
I'm trying to upload the .rte file but it doesn't work.
Can You explain?
BTW you should got the same file by e-mail yesterday.
Rafal Gaweda
Message 45 of 51
jsanders
Is there a way to contact Autodesk FRANCE ? Since the French .rte template is broken, they didn't do their job, didn't even bother to check if it was working or not.
Message 46 of 51
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jsanders
Revit development is made worldwide.
Mostly in US.
Rafal Gaweda
Message 47 of 51
Very insightful and informative video that is not just useful to the readers but also revealing.
Message 48 of 51
for future reference: you cannot attach rte files here. Zip them first.
Message 49 of 51
jfbrigaud
I noticed the same problem, I use the French template: DefaultFRAFRA.rte (version 2019.1).
I solved this problem by removing the 3D view (by default) and recreating it.
Bonne journée.
JF
Jean-François Brigaud
Message 50 of 51
filip.JacobsonM6BFW
Community Visitor
Community Visitor
I Think I found the problem since I had a similar crazy perspective view…
In my case, there was a linked dwg from the municipal with height curves roads etc which was super big.
This made ther perspective go bananas… So I tried unload that specific dwg.
Then i chose two random walls in a plan and opened in 3d with a sectionbox..
Then I unmarked the sectionbox and the perspective looked as it should after that.
Hope it helps.. 😉
Message 51 of 51
Jpetitclerc
Does 2019 have navigation wheel? I'd hit CTRL+W to get it on and would replace the center on a wall near the center, maybe?
On dirait à ce moment que Revit replace un peu l'orbit, peut-être que ça corrige la vue?
"It seems at this point that Revit is somewhat replacing the orbit; perhaps that corrects the view."
