PDF print - lines overlap
Hello everyone
I have an issue when I print into PDF format.
Basically the dominant lines are overlapped by secondary lines.
As you can see in the example I posted, the black line should be the dominant one but it is crossed by the curtain wall projection lines that it's located at least 5 meters far from the section line. Do you know how to solve it out?
Thank you very much 🙂
L.Maas
You might try a different/updated PDF printer and see if that solves the issues
Louis
Please mention Revit version, especially when uploading Revit files.
Hi L. Maas,
It is working! I just used another PDF printer and the problem doesn't show up anymore!
Thank you for your help 🙂
Viveka_CD
Hi @Anonymous
Can you confirm the version of Reit you've used and the PDF drivers you used?
Also sharing this collection regarding PDF printing errors that may help the community seeking similar answers.
Hi Viveka CD,
Sure! I used Revit  2019. The PDF printer I used to make it work is just the one privided by Windos 10, "Microsoft Print to PDF".
Hope it will be usefull for the comunity 🙂
Viveka_CD
