PBR Glass roughness maps are inverted [BUG]
JM_Koester
JM_Koester
The roughness maps for PBR glass materials are inverted by default.
To achieve a correct result the map has to be set to "inverted" again.
I assume this is a bug.
JM_Koester
I would appreciate if someone could confirm the issue.
Thanks!
pawel.romaniuk
@JM_Koester
Please elaborate. screenshots, file etc
Pawel Romaniuk
JM_Koester
When creating screenshots I realised that it looks correct when rendering in high quality.
Viewport raytracing and medium rendering gave a different result, therefore the map works as intended it was a mistake on my side.
