Pattern rotate
Pattern rotate
Jose.RodriguezTPWSZ
Pattern rotate
Jose.RodriguezTPWSZ
Hej
I need to rotate a pattern in REVIT. It is the concrete patter, but for no loading Walls I would like to have 135° orientation. Is there any workaround without editing the PAT file. In case I need to edit the PAT file. Where are they stored in REVIT: I am working in 360 cloud.
Thank you for your answers.
Mike.FORM
The default patterns that come with revit are found in C:\Program Files\Autodesk\Revit <year>\Data and there are two .pat files in that folder.
If you need to rotate the pattern you can use this free website to do so.
https://pattycake.io/new/drawing
Jose.RodriguezTPWSZ
vielen Dank
