- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was testing workflows where we could set some doors (a door to a locked/secure area for example) to be considered obstacles by the Path of Travel tool. The idea would be to set the door category as an obstacle, then hide any doors that are not to be considered obstacles. The functionality of the Path of Travel tool implies it will route through the wall openings left by the hidden doors and treat the visible doors as obstacles. In this screen capture you can see the settings as well as the path of travel line routing through a door that should have been considered an obstacle.
Link copied
