PASTE from one view to another in same position
wisedrawing
Message 1 of 9
wisedrawing
Hi all
seems simple but I just can't find the answer, control C an item from one view like site works plan and paste control V into another, its shows its original position but I can't seem to find the key to getting it to snap into that position, I am left clicking or enter and it will place it where my curser is, see video
cheers
Replies (8)
Message 2 of 9
ennujozlagam
are you paste into another file? it could be they have different coordinates. draw a reference line as a marker to match the new file and see if helps. thanks
Message 3 of 9
CTRL + SHIFT + V or right click Paste Aligned
Message 4 of 9
wisedrawing
its always amazing how a tiny little bit of feedback lets the brain work it out
heres how it worked for me - note the Cntl Alt V just gave me the alarm bell??
but that made me look at the paste ribbon and there it is 'paste aligned to..... etc.'
Message 5 of 9
wisedrawing
this was just a simple duplicate view site plan and site works plan - otherwise I assume its going to be harder to do, cheers
Message 6 of 9
SHIFT, not ALT. That shortcut is out-of-the-box.
Message 7 of 9
wisedrawing
Control + shift + v  - still alarms me?? no go
also right click does not give me any paste options - maybe I need to custom something on the right click menu?
weird hey?
Message 8 of 9
martijn_pater
Check your shortcuts.
set cntr-shift-v to same place or level (autocad standard)set cntr-shift-v to same place or level (autocad standard)
Message 9 of 9
wisedrawing
Thanks heaps, that worked and it was unpopulated - to enter the shortcut you have to so the contl shift v in one go, you can't press one at a time or it wont enter it which nearly had me stumped but then success
