Material take off to be performed on the parking kerb. the kerb is with two paints, yellow and black for 700mm length each, and material take off to be performed for each paint separately. I tried using the split face tool and its cumbersome. and im planning to create a family with 700mm length, still im not sure about the family category to use.
Pl help me on this,
Im using Revit 2020 and its a LOD 400 modeling phase.
Awaiting for your advise. thanks in advance.
Maybe use a linebased family with 2 volumes for the materials arraying at 1400mm each?
For curves use a custom family wich can deal with arcs.
I usually use the Generic category because many other categories aren't cuttable.
How accurate does it need to be? besides the Material takeoff Area would include all sides (below, back etc)....
- Michel
Why not just use a System Family like a Floor Slab Edge or a Roof Gutter/Fascia? You can apply "paint" (e.g. Material) to the faces of those sweep extrusions in the Project using the Paint Tool on the Modify Tab.
Thanks for your reply @TripleM-Dev.net and apologize for my delayed response,
Material at areas expose to view.
Also Pl advise if we can you generic components in the LOD 400 model instead of specific category?
Thanks for your reply @barthbradley and apologize for delayed reply,
We need to use two materials consecutively at every 700mm.
@PrathapSekar wrote:We need to use two materials consecutively at every 700mm.
Here's a recent topic discussion on curbs: https://forums.autodesk.com/t5/revit-architecture-forum/how-would-you-model-a-curbstone-in-revit/m-p...You could have a look at modeling it as railing. edit: actually in your case perhaps the curtain wall method, using two panel types, or as adaptive family.
ow, meant to add the attached as example (edited example file for 2 types/materials).
