Parametrize "Fillet Arc" between 2 arcs
ODP_MED_CRodriguez
ODP_MED_CRodriguez
Hello everyone!!
Is there a way to parametrize a "Fillet Arc" between 2 arcs?
I have this orthogonal form: it is composed of arcs on each side (Black), and each arc is joined by a "Fillet Arc" (Red). The arcs are already parametrized; they respond to a general "Width" and "Depth" of the entire figure, and the height of each arc also responds to a specific Arc-height parameter.
Without the "Fillet Arcs," the general geometry responds very well to the existing parameters, but once I create the "Fillet Arcs," restrictions appear. So I would like to know if there is any formula that allows not only adjusting the general dimensions without issues but also changing the radius of the fillet arcs. (I can sacrifice this last option; it is possible to just adjust the general dimensions without issues.)
Thanks in advance for any advice.
ODP_MED_CRodriguez
Sorry, in the last screenshots, the "ODP_Corner_X" and "ODP_Corner_Y" parameters don't have any function. I was just trying solutions.
