Hello everyone
I have an issue aligning the short vertical lines, which indicate the place where the paper has to be folded, to the margins of the paper. The vertical marks are grouped and have group array parameter depending on the width of the paper.
Please help🙏
Thanks!
Hello everyone
Please help🙏
Thanks!
Solved by RDAOU. Go to Solution.
Array or Floating lines can be very unpredictable...If you want to stick with that, I would suggest the following
Attached is a Revit 2022 Version, maybe you can open it and see how it is constructed. I do not have 2021
FWIIW: Personally I neither like nor recommend the all-in-one Title Blocks. It is more practical to create a different title block family for different paper space
